FJ_Russo
- Mar 14, 2010
- 350
I have a 1972 Steury Craft model v415 listed at 810lbs, 14'6" semi v hull rated for 60hp engine.
The engine is a 1968 65hp v-4 Johnson. with a current 10X9 1/4 prop.
The max RPM at WOT listed for this engine is 5200, at WOT I'm around 43-4400 RPM's.
I played with the trim and tilt in all the positions this engine offers and found the best spot but still getting the low RPM's
I'm ok with me and another person on board getting on plane but she won't get on plane with a skier behind and with a full load 4 average size people its slooooow going getting on plane. Even when I'm on plane I never get that full throttle sound the RPM's just aren't there. I can't find a lower pitch prop for this engine anywhere. Anyone with any ideas on a pitch and diameter I should be running on this set up??? Iboats doesn't even list a pin drive propeller for my enigne that is 10X 9 1/4 is this even a size I should have on my engine?? Any insight would be VERY helpful. My boats no fun right now
