Is it possible to get a used VRO/Fuel pump for a 1987 GT150 Johnson motor. I priced the new ones at 450-500 bucks. Would like to find a cheaper alternative. Thanks.
Bombardier sells a replacement pump which does not have the oil pump side. Basically, you have to premix your fuel with this pump. Saves about $100 over the type of pump you have now.
A fuel pump is something I would not consider getting used. What is wrong with the current one ??? You could re-build the fuel side of it, block off the oil side and pre-mix the fuel.
Another option is to put two (2) conventional pre-mix pumps on to support the volume needed for those 6 cylinders. Bit of bracketry and fitting needed for this one though but it would be cheaper.
