Re: chrysler 55 no spark
1. Did the points look dirty or burned? I?ve had a 1970, 35 HP Chrysler since 1985 and possibly changed the points in 1985 on G/P vs a need. Usually the points are Tuff if clean and set at the proper gap (0.020)?? Did you check to see if the points rubbing block was not broken and the points were opening?
2. Did the coils look normal vs cracked or corroded? I?ll attach my working system
3. Did the condensers look to have good connections? Seldom, will a condenser or coil go bad, and I have used a car?s basic condenser during quick troubleshooting vs final use.
4. Last, is low voltage getting to the ignition system from the switch? This should show vs me testing.
Help is coming or you?ll find the problem but spend at a minimum w/o knowing the problem.
Good Luck Again!
JOW
