i have a issue with the engine surging and misfiring between 1300 and 2400 RPM'S, i cleaned the carbs and adj the floats and changed the plugs and nothing still the same.
i started looking backwards through the electrical system and coils are good and CDI read 50Ohms thats good and the stator should read (700-900Ohms) on each coil set and one reads 570 and the other reads 730Ohms. what would the low resistance do and is this the reason for the surging and miss-firing?
