Well here goes. I have a 1978 Mercury 6 cyl. that worked OK last year. Had a time where it wouldn't quite go in reverse, but I adjusted linkage and got it going again. Here's the problem. removed engine from boat to make some boat repairs, removed cables etc. Put all back on. Replaced impeller, and reinstalled, no problems re-installing. Ran boat with muffs and shifted ok. Now comes the odd part, for me anyhow. Put the boat in the water & reverse grinds, but wont lock in. Adjusted linkage to no avail. Any help, insight would be greatly appreciated. Again, Forward- Good , Neutral - Good....Reverse gr & no lock. Manually the prop goes through the correct cycles out of the water not running, I'm going crazy trying to figure this out.
