Re: water deflectors
Here are some photos of the "pipes" ... Upon closer inspection I saw there were two for each toon, each about 1/3 of the way from the ends. My friend says he thinks they are used for pressure testing since all four of them are threaded. And I measured and they are 1"
Also, they might LOOK like they are some sort of PVC or plastic, but they are all aluminum and are welded to the 'toons. They are white because the dumb*** that had the boat before me decided to paint the logs with some sort of ugly epoxy that I haven't been able to get off. I have never had a problem removing any sort of coating from anything because I have a 3500PSI pressure washer that pumps 5.3 GPM and has a 200 degree heater on it. It didn't even budge this stuff... I tried aluminum brightening acid, superstrong degreaser, paint thinner, and some blue gel from Home Depot that is supposed to remove epoxy. The gel started loosening it, but it would take FOREVER to use this stuff with as thick as this guy caked it on. ANYWAYS, needless to say I wasn't happy about this.
