99 EZLoader/Larson Trailer, I want to replace the damper. How does this actuator/coupler disassemble? The rear pin slides out and it would appear that if you disconnected the brake line and pulled the forward pin, the whole assembly would slide forward and out. How is the forward pin removed?? I have removed the snap rings but it refuses to push out. The forward pin goes through the damper and spins freely. Bigger Hammer??
