I have an Evinrude 50hp I think it is a 1975??? (No tags or freeze plug numbers). I also have a Johnson 60hp and I think it is early 80's. The engines look basically the exact same. Even the covers will swap and look the same.
The Johnson 60hp lower unit is in the shop being rebuilt and it is the great running motor (the Evinrude 50hp needs alot of work). I decided to take the lower unit off the Evinrude 50hp and put it on the Johnson 60hp so I could use it over Memorial weekend. It looked the same and bolted on with no problem. I thought for sure it would work fine BUT when I throttle forward it goes in reverse and the reverse throttle goes forward! This of course ruined the weekend at the lake since my forward speed was governed by the reverse throttle stop. I didn't run it long at all. Just wanted to run some new gas through the carbs. I sat for an hour or two and I'm completely puzzled by how this can happen! Can someone please help me! The props both are right turn so the rotation should be the same. What did I do wrong? I would REALLY appreciate some feed back. I don't have a clue what happened.
I'm going to put the rebuilt original lower unit back on next week BUT I'm worried that if I did something wrong and do it again, I will have the same results with it! Is there a difference in the lower units causing the problem or did I do something to cause this? Thanks
