Re: 175 gt to 235gt
Dhadley has offered some good information. You will need an early set of 235 big bore high compression heads: 325638/639. They were standard on the first big bore 235's and were also found on the later 2.6 XP/GT models. Look for 6 of the rubber intake stuffers: 322722. They are NLA, but worth scrounging around for. These were on all 200 and 235's but were dropped when the engine was derated to 175. Worth 5-8 hp. The 2.6 models came with composite reeds from the factory: you might want to consider changing to them. Your engine already has the 1 3/8" carbs. Most of those 175's had plastic carb bowls. You may want to check them for flatness. These always tend to warp and they often leak fuel and can cause lean running conditons if they are out of flat in some places. Your current power pack is rev-limited at 5800-another HP limiting factor.
