schooner614
- May 31, 2010
- 5
I need help. I am trying to get my boat back in running condition after sitting for 3 years - in my garage in Louisiana. Prior to this the motor worked great - no problems - although 20 yrs old have only put 30-40 tanks of gas through it! However, it was left outside for a few months where water collected and flooded the starter and rusted it out - drain hole plugged with algae. I replaced the starter and battery and put in new plugs.
The boat sat with 1/4 tank of gas during the 3 yr period - no stabilizer was added when it went into storage. I added new gas on top of the old and tried to start the motor. It attempts to start - but the only way I can keep it (very roughly) chugging is to rapidly pump the throttle - can keep it chugging for 30-45 seconds - barely - but as soon as I slow down the throttle pumping - it immediately dies?? During the rough chugging it is backfiring every few seconds. What do you think the problem is? Does it sound like a fuel supply issue? I have not touched the fuel delivery system? Should I take the fuel pump off and replace the filter? Do I need to suck out the gas tank and start will all new fresh gas? I did add a bottle of heat in case there was some condensation in the tank over the 3yr storage period - inside. Could it be a distributor / points issue?
Any advice?
Any advice?
