hat_trick_rick
- May 31, 2010
- 3
Hi-
Need advise. I have a 1988 40HP Johnson Motor with a disconnected VRO pump. There is some gas leakage traceable to the vicinity of the pump (on top/around). It could be the connectors or a gasket on the pump. I am thinking it is best to simply replace the pump with a standard pump. Presumably, I'd have to pinch some of the lines permanently closed? What is the correct pump #? Is there a more reasonably priced after market pump to put in there? Details please, including any specific instructions, much appreciated. Thanks!
