Merc 5.0 won't die
SPOONMAN1
I have a 93 crownline with a 5.0 and after pulling a board if I want shut off the engine I usually have to make 2 or 3 attemps before it dies. I'm afraid of it reversing rotation and taking on water, otherwise it runs good. What causes the dieseling? thanks
Fishermark
Re: Merc 5.0 won't die
Make sure it it not idleing too high. Also give it a few moments at idle after an extended hard run before shutting off.
SPOONMAN1
I am not sure how high it should be idleing, but it seems to be close to 7-800, I have let it idle for about 20- 30 secs, It will turn off after several attemps, but wasn't sure if it was the carb or something else.
