meichinger
- May 31, 2010
- 2
I have an intermittent dashboard alarm in my port side 4.3L. From other posts I understand it is probably not the temp or oil pressure alarms as those are continuous alarms. So the only other alarm I know of is the gear lube monitor, which is an intermittent alarm. I disconnected the two leads to the port gear lube monitor but the alarm still sounds. Any ideas?
There is no alarm when I run only the starboard side engine.
Thanks,
Mark
Thanks,
Mark
