NO FUEL
sixxhunter
I have a 19?? ESKA 5hp model#1142-b.Up until a week ago it ran fine,then it would only run wide open.I located the cause,no fuel was getting into the engine at low speed's.I was told that I had A crankcase leak or carb problem,I rebuilt the carb and put new seal's in the case,and it ran great.I went to the lake two days later,and had the no fuel problem again? Now it will only run when I dump fuel in the carb.The engine has A built in fuel tank above it. I have great spark,and great compresion,just not sucking any fuel.I checked the line's and filter they are fine.Also does anyone know what year this engine is?
johnkc
Re: NO FUEL
post your question over on the outboard forum ,you will get some answers there.
