flyboyziel56
- May 30, 2010
- 6
Hi Guys I'm new to this forum and in need to some serious answers!. I have a 1994 ocean runner V6 150. I have had this boat/motor for less then 6 months. I had it checked out by our local boat shop and they adjusted my controls and gave it a clean bill of health. I was on the water this weekend and had been towing my grand kids around when all of a sudden the engine slowed down and just quit. I checked the fuel bulb and it was tight. I checked the VRO oil reservoir and it was still full. the alarm on my controls didn't go off for the VRO. I never changed the impeller when I first got the boat, and when I had the shop check it they said it was fine. Does this engine have a thermostat?. Could it have overheated?. When I got back home I took a compression check on all 6 cylinders and found the starboard side lower piston had only 55 PSI. All of the other ones had 120 PSI. looks like I'll be rebuilding a power head!!. Can the power head be rebuilt with the block still attached to the lower unit?, or does the whole thing have to come out and be separated?. Any suggestions on a place to pick up parts where you won't get raped?. I have pretty much a complete machine shop here in my house so the machining process will be done right here!!. any and all replies are much appreciated in advance. Thanks Allan
