what is the drain hole for?
bgooden
I have a 73 aquasport 22.2 center console . What is the drain hole in the front of the boat for ? It only drains water when the front of the boat is down ,when i hook it up to my truck. I just want to make sure i am not holding water. Where does it drain from?
scottsally
Re: what is the drain hole for?
do u have a live well up front? or a storage for the anchor
Huron Angler
There should be a plug that goes in there when not draining it, so the boat doesn't take on water. Otherwise there might be a one-way inline valve.
It's best to keep them plugged, but you should drain any splash/rainwater while the boat is on the trailer to keep things dry.
