Don Brewer
- May 29, 2010
- 2
I am going to replace the 2 piece rub rail on my boat. The problem is that the front is so pointed that in order to make the bend logic tells me that the OEM replacement rub rail will deform so badly it will not be able to retain the insert. Because the existing is already broken I cannot tell if the factory placed a mitered joint their, however the insert is continous at the apex of the "point".
The boat is a 1993 Malibu Spostster Flightcraft,( the hull resembles a low profile
Jet boat). Please help!
