AzogNewOrleans
- Mar 15, 2010
- 24
This is the Frankenstein motor I bought. I had it out 3 times already runs great. When I put my plate on my trailer the other day I see oil leaking from a small hole in the flat surface above the prop. There was no oil leak before. Coffee colored lower end oil I think. Is there supposed to be a hole there? I didn't see it there before. The pic is not my motor but the arrow shows where the leak /hole is located. I am going to drain the lower end oil tomorrow, if the hole is just a pinhole the wore through with corrosion I am going to JB Weld it closed , clean and re-fill my lower end but don't want to close up a hole thats supposed to be there obviously. Frank helped me before with this motor, the knows the one. Aso need to know what oil goes in lower end on this antique.
Azog
Azog
