new sterndrive now boat won't reverse
86 Larson
I bought a rebuilt sterndrive and installed it. Now my boat has no reverse or neutral it just goes forward and full throttle no matter where the throttle is. Any ideas?
Alpheus
Re: new sterndrive now boat won't reverse
What kind of stern drive?
Alpheus
Did you have the shifter in forward gear when you removed the old and installed the new one? Are you sure you have the "shifter foot" in the "shoe"?
I would start there, and make sure your shifter fork is not bound up...
86 Larson
Yes on the first thing. I am pretty sure on the other.
86 Larson
Is it possible that I could have put it in the shoe backwards? Would that cause my problems?
86 Larson
Thanks for your help I will look at it more tomorrow. Thanks again
Alpheus
I would start with that. Double check your work. If the throttle worked before I would suspect a cable binding up...
Also welcome to iboats. Check out the adults only section and download the manual for your outdrive. Thats a great place to start...
