1993 4.3lx When I first take the boat out it runs great. when I restart the engine after stoping for a period of time 20 30 min it will start fine but when I advance the throttle and start to get up on plane the engine will alnost shut off. If I back off the throttle it might stay running or spit back through the carb and die. The last time it ate the starter sun gear and found water in the 2 rear Stdb cylinder, Engine was locked. replaced starter pulled plugs turned over blew out water and started, ran good using muffs for cooling. If it is the intake can I use a automotive Edelbrock manifold.
Any help.
Any help.
