Hello
I have a 1980 merc 140 that came on the boat I bought last year , I was told that it runs but only up to 2000 rpm then loses power. I posted the question what the problem could be and was told to do a compression test and it could likely be a high speed stator. I have'nt done anything with the motor except store it over winter with storage spray and fuel stabilizer in the tank.I now have contacted the previous owner and he now states a mechanic diagnosed it as a blown reed valve and he could'nt recall which cylinder. This motor was fresh water only and used this only 2 weeks a year until 2008. It looks mint inside and out. The question is what would be the best way to approach this issue now. He said that it would have to be pulled apart to see what damage has been done. This means taking it to a shop of course. What would one expect for hours of labour and any likely parts it will need.I would like to revive this motor but not sure if it will be worth it now. your advice like always is greatly appreciated.
