I know that a continuous alarm is an engine temp. issue, and an intermittent alarm is a VRO/oil issue. I have read on several posts people saying that an intermittent alarm could also be a fuel restriction issue. My motor is a 1987 Johnson 150. Does it have a fuel restriction alarm, is so can you distinguish it from a oil related alarm.
As far as the buzzer in the control box. It has a tan wire on one terminal, and two purple wires on the other terminal. The buzzer has power, but on the diagrams I've looked at, they show a black ground wire coming directly out of the unit. They say it should buzz a second or so when I turn the key on, but mine doesn't. Where could I order a new alarm? Any suggestions, comments, and replies would be greatly appreciated.
