Spark plugs on a 35hp Johnson Super Seahorse
flyfishtoday
Hi all,
I am looking for the brand of spark plugs and proper plug gap for my 64 model super sea horse outboard 35 h.p.
Thanks for your help.
lindy46
Re: Spark plugs on a 35hp Johnson Super Seahorse
The last year of the 35hp models was 1959. You must have a 40hp if it is a '64. Use Champion J6C plugs gapped to .030".
flyfishtoday
The motor cover says it is a 35 H.P ,but the boat title says it is 64
Would the plugs and gap be the same?
Thanks
cougar1985
.020 and .030 cover omc motors for many many years..020 being points gap and .030 being the plug gap.boat title .numbers etc mean didlly squat for the engine as it could of been changed a hundred times by now .look for a rectangular metal plate on the motor transom bracket or the number off of a metal welch plug on the motor proper.post results.
R.Johnson
The proper plug is a J4C.
glassmaster68
yeah,i have j4j which was later changed to a j4c,,,,,,,j4c,,,,.030 gap
samo_ott
You might have a 33hp but they didn't make a 35hp in the 60's. as mentioned, look for the model number on the transom plate. The plugs are pretty much the same though.
R.Johnson
Most model's from about 1958 on, and with conventional magneto ignition, and equiped with a thermostat used J4C gapped at .030.
