I just bought this boat 26' cruiser io with a 2008 mercruiser 5.0 mpi
the engine is extremly clean and well cared for. However as soon as i put it in the water it started overheating. We checked raw water intake by removing a line to see if water was coming in. Yes it was, and very well to boot. I hooked up a fresh water hose to intake while closing the saltwater intake. Turned on hose eng temp went from 230 to 170 in minutes. However if while im putting pressureized fresh water through the system i open the salt water intake and the fresh water goes out of it instead of continuing through engine, and it overheats. Now this is a pretty new engine 2008. Could the water pump be a problem? Is there another pump called a raw water pump, and could that be the problem? The boat was winterized correctly. There is no water intake from the outdrive, only discharge.
Please help if you know.
