Re: polarcraft
There are lots of ways to get fuel out of a tank. 1) Siphon through the fuel tank filler. 2) disconnect the fuel line at the engine and pump it out. 3) Stick a hose down the filler and pump it out. No need to remove the siphon tube (whatever that is). You can remove the anti-siphon valve at the tank, replace it with a standard hose barb, extend the fuel line over the side of the boat and siphon the fuel that way. You cannot siphon fuel with the anti-siphon valve in place.
