nathanhooper
- Apr 21, 2010
- 176
I am cleaning/rebuilding this motor. I say that with some exaggeration because it is probably the cleanest motor I have seen. Not sure the whole story on it, but it doesnt seem all that used. I have pulled the carbs, fuel pump, and replacing the hoses. Other than that I do have a few questions on what some of the other hoses are on the motor, but I will post pics with questions on that later.
My question now is that I have a manual for it and for the most part it is very helpful. But when I get to the timing and synchronization section, it skips right over my year model motor. I have seen this in wiring diagrams, seems that the 1979 inline six's were a tad bit different than others. The manual does go on to 1980 and the pictures in it seem to match up to what I have. Will it be the same procedures? Also if I cannot get a dial indicator, can I use a caliper? What surface does the dial indicator measure from? Top of plug threads or the bottom of them?
Anyone ever do a timing and synchronization with these motors? From what I have read it seems that I might have just picked up a real gem and I want to make sure that I set things right so it will last as long as they say they can.
