Having problems all at once. Almost impossible to get boat on plane. 1989 Evinrude 40 hp on 17 foot aluminum boat. Wide open it slowing builds up rpms and after a long tme and slowly trimming up it will get on plane. I have read on here that it could be s spun prop. Does that make sense and how can I check to be sure. #e40tecec. After finally gettting on plane I can acheive max rpm and also the boast is not overloaded. Also I have an extra prop I could try but it the boat is 50 miles away. Does any body know the size of the prop nut so I could take the correct size socket. Thanks.
