See number 29 in this link.Hello, I have a Mariah 18FS with the mercruiser 3.0 with a TKS carb on it (2006) I do I replace the carb filter. It looks like were the filter goes is a solid piece and does not look like it would unscrew. any ideas????????
Yes it does unscrew, It's torqued down to (18 lb.ft)Boat Tech thanks for the follow-up - my concern is with item #12 it looks like that part does not unscrew, the fuel line goes in the center on the nut. I tried to unscrew the bolt but it seems to be solid to the carb. This bolt does unscrew right?????
