I have a 1996 225 Carb. Merc. Last Sat.,after running about 2 1/2 hours out to the ledge and then trolling for about 45 min.,my motor kept shutting down.It would start back up but when you got over 1100 rpm,s it would stall.If you went WOT most of the time it would go. I have had a simular problem before and found the bleeder check valves getting clogged up.I have replaced all of them now.I noticed with the throttle at 3/4 open I was only getting about 2800-3000 rpm,s.Any suggestions on which way to go on this? My engine serial no. is OG423431
