louluvscookies
- May 25, 2010
- 9
I have a 95 130hp johnson. It overheats whenever ran at much more than half throttle. Tested it with heatgun, found out it always the starboard side getting hot. Both sides start out running close to the same temp (130 to 140deg) but after operating for a few minutes the starboard side starts to creep up then takes off to 170 deg plus. The alarm sounds and motor gos into slow mode. When I slow to a idle the temp slowly comes back down. I just bought this boat but the previous owner had overheating problems. He took it into a marine shop and they resurfaced the heads, put in two new waterpumps, and new thermostats. They thought they had the problem taken care of but I guess not. Since I've had it I put in another set of thermostats, then swapped new thermostats side to side still overheating on the same side. Took thermostats out and both sides ran the same temp. I've read about a pressure relief valve that can stick but don't know where to find it. Any help would be greatly appreciated. Thanks
