I purchased a dinghy with a 2003 Mercury 15hp 2-stroke outboard at the end of the season last year. Only went out a couple of times, but it had no problems starting after a few pulls. Followed standard procedure winterizing the motor (changed the oil, new plugs, fogged the cylinder, etc.) and stored it in my basement.
At the beginning of the season I went up to the local BP station and filled up the gas can with 87 octane and mixed in the oil. The engine started up like a charm on the second pull. Ever since the dinghy has been in the water (almost a month now) it's getting harder and harder to start. First couple times it was 3-5 pulls, then the next weekend I noticed it took 7-10, then the next weekend 15-20. Then tonight I went to go for a ride and it must have took me 30-35 pulls to get it started. Once it starts all is fine, it stays running, runs great, no hesitation, no stalling, nothing. I follow the same start up procedure each time by squeezing the priming bulb and pulling in/out the prime knob 3 times and leaving it out until it starts as the manual recommends.
Admittedly, this is my first outboard and I don't know much about them. I am hoping some of you can offer some suggestions on what the problem might be. Is it possible the problem is the gas? One thing I thought of tonight that I'm not sure about is the gas can has a vent on the cap that you turn to open and close. I have always left the vent open. I am wondering if leaving it open all the time while the dinghy sits in the water is a bad idea? I do cover it, but leave the gas can in the dinghy.
Any help would be appreciated.
