Re: Resin Questin
The curing isn't what changes the weight, any change in weight is from it being open to the air, small amounts of styrene and other volatiles can escape during this time. In closed mold processes the resin doesn't really come into contact with air, so only very small amounts may evaporate. In spray applications you may loose several % in weight as the resin is atomized and the styrene flashes off.
Epoxy would be similar and the amount of weight change would still be dependent on the solvent escaping, which is normally added at a lower %.
Why the question?
