1969 6HP Evinrude Fisherman
Drum90
I have a 1969 6HP Evinrude Fisherman and I am replacing the head gasket on it. I was wondering if anyone knows the torque specs on it. Including the sequence.
bob johnson
Re: 1969 6HP Evinrude Fisherman
I have one and just got the manual a few weeks ago, if you dont get an answer, when i get home ill post what it says about your torque specs.
bob
Drum90
Thanks that would help me out alot I havent been able to find anything on that.
bob johnson
60-80 INCH POUNDS for cylinder head screws,(as printed in the torque chart.)
for the sequence.. in a clockwise circular rotation starting in the middle on the left with 1, then to the right across the middle to the other center as 2, then down one hole for #3, the across to the hole below #1, for #4 then to the hole above #1, ... then across to the hole above # 2.... growing larger in dia and continueing in a clockwise rotation...
thats the best way i could describe it..
good luck
bob
cajuncook1
Here ya go!!
Cylinder head screws torque range is 60 to 80 inches pounds
Borrowed the picture attachment from Jay Merrill :)
Good luck my friend,
cajuncook1
