16.5' Sunbird bowrider/ 88hp Johnson..
I replaced the trim tab because it was completely Missing. Though it didn't help this problem, I can adjust the tab to a point where the boat will "Pull" Right or left. But my problem is going straight.
Boat turns slightly left, I correct slightly right. Now boat goes right and I correct left, Boat goes left, I correct right...Cuss and Repeat, Cuss and repeat.............
Now this is at Lower speeds and Not On Plane ! It does much better on plane, Though still there it's less problematic..
I have checked for things like Slop in the motors steering, By trying to move the motor back and forth by hand. It has very little play...The Steering cable is stiff making the constant steering a un-invited Workout !
Could this be a Prop Problem ?? The Prop is a 13-1/4 X 17...
