I own a 1997 40hp Force outboard on my pontoon. Last year every once in awhile when i turn the switch to off, it wouldn't shut down the motor. As i quickly moved key to off on off on after a few times it would shut motor off.
This year i replaced the ignition switch to solve the problem, so i thought. With new ignition switch wired my motor still wants to run in the off position.
My tether switch when pulled does not shut motor off either. Is there an easy fix to wire up a kill switch? Do i need to replace the tether to solve the problem? Any suggestions to this problem would be appreciated.
