I have a 1999 Crownline that used to have a 5.7 vortec with 2 barrell carb that crapped out on me so I put a 350 mag mpi in it out of a 02 Crownline. The only problem that I have ran into is that it has a sea water pump on the motor and my alpha drive has the impeller to cool the system. So I was wondering if I can run them in series and be safe or if I need to choose one or the other? I could pull the sea water pump and replace it with an idler pulley but will the alpha drive impeller be enough to cool this bigger motor? Or can I buy a pick up system for the sea water pump and just plug off the hose from the alpha drive? I don't want the outdrive to heat up and crap out either. Has anyone else ran into this problem and if so what did you do to resolve it?
