Re: Mercruiser 120 help
My 67 Stingray has a 120 in it. It is a 66 but I just did the major overhaul on it. Everything new except crank and had it turned. I have it mounted to an 89 merc outdrive. Exhaust didn't line up and couldn't find any adapter, so I had a stainless pipe and flange made up and it now has through hull exhaust. I mounted the exhaust flapper on the end of the pipe so water can't back up into the head/valves. It sounds real sweet when your being towed on a tube.<br /><br />As for your question on porting, I think that just about anything that can add to your flow threw the heads is beneficial. As far as the outdrive goes, you need to make sure that you have the right ratio. Just because it may have been for a big six or eight it may handle the extra torque, but without the right ratio, your prop speed my be slower due to the difference in ratio between the 8's and 4's. I personally don't exactly know what the ratio is. I don't work on them everyday to have the numbers imprinted in my brain. Trent will probably have the answers that you need to know. He is a Wizard of Marine Mechanics. Good Luck
