ID this Starcraft.
wvmedic
I think it was a 1980 or at least it was in the 80's. It was our first Starcraft, I liked it a lot. It was light towed well, however it was an OMC with the 3.8L V6 and the block cracked from PO not winterizing it properly. When I got it I had to rebuild the starter, I got it going and put it in the water that is when I found out the block was cracked. It sure did run good though.
Jeff
