Re: electronics
Do you know what's wrong? If not, you don 't need parts -- at least not yet. Did it occur to you that the circuit breaker (if you have one) might be tripping, cooling off, then resetting? They do that all by themselves because they are designed that way. They trip because too much current is being drawn. Too much current is being drawn because there may be fish line wrapped tightly around the prop shaft between the motor housing and the prop. Remove the prop to check. But before you do that, spin the prop by hand. If it feels like its binding, the bearings may be tight. THEN you need to find parts. If the prop feels a little jerky as you turn it, that's normal.
