Re: '94 200 HP Merc Oil Alarm
Thanks for responding CharlieB.
<There is no sensor in the remote tank.>
The remote tank on my boat has a float switch, maybe this is for the oil gauge on the dash? I'm not 100 0/0 sure since I just purchased the boat.
<The sensor in the cap of the engine mounted tank is very sensitive, loosen the cap while running, wait until oil just begins to leak out from under the cap then retighten. The wires get twisted cause someone plugged them in before installing and tightening the cap.>
I'll do as you suggest as far as filling the engine mounted tank. As far as the wires being twisted, this is how they were when I got the boat, but I'm inclined to changed the cap just to eliminate the possibility of this being part of the cause.
Also, when I loosen the cap with engine running like you suggest is it safe to assume the pump is good if the oil level rises?
<The alarm module compares the rotation signal from the oil pump to the ignition pulse on the green wire to coil of cyl #4, any difference in the two signals then the alarm sounds.
Check spark on ALL cyl's, misfiring on #4 will cause an oil alarm.>
The engine seemed to be running smoothe. But I'll see what I can do to check for a misfire on #4 as well as check the connections at the coil. Thanks for you help with this.
