When I turn the key the starter turns over a few times and then the starter runs constantly. The only way to stop it is by turning off the master switch. When i turn the master switch back on it runs constantly. Is the problem in the master switch or the ignition switch? It won't start when it is doing this either. I have already replaced the starter and solenoid. It is a Johnson 175 V6
