Re: Evinrude Dual Fuel Connector
Yeah, you need a pressure tank and that is not one. If the motor had been converted already and has a fuel pump, you just need to buy a standard omc fuel line assembly or fittings. If not, you have one of two options, buy a used pressure tank with the fittings/connectors (sometimes people sell them without the connector to the motor and those connectors are really hard to find and expensive when you do) or convert to a fuel pump and use a standard tank. Either way, you'll have to invest another $100 give or take.
