hey guys. the description says it all. i was rebuilding my carbs this evening an i forgot to turn the battery switch to off! the wrench was on a bolt and the handle hit a live wire and bzzzzzt bzzzt sparked. i turned the switch to off and finished the carb i was on. i wanted to tilt the motor up for the night and finish in the morning but the motor wont tilt now. probably wont start or choke either. i switched the battery switch from batt #1 to batt#2 and still nothing. the stereo still works so batteries are fine. do you guys have any advice where to look for a fuse or something? the battery has two wires(+, -) going straight to the motor and two other wires(+,-) going to accessory fuse panel under the dash. its a 1989 v135 black max. dont know where a main fuse might be on the engine. do you? Thanx a helluva lot guys! Erik
