4winnsskipper
- May 9, 2007
- 204
Hey guys, my 96 , 17' four winns with 3.0 Volvo Penta is used for trolling. I run a 20 pitch prop and recently installed a trolling plate to slow the boat down to 1-2mph without idling the boat so low the engine shakes and loads up on fuel... welll i did that now i need to actually run the motor around the 1,000 RPM mark to get my speed (plate works too well)...also steering has become a slight issue, it doesn't respond like it should. im thinking i should drill a hole in the center of the plate ( right in line where the water shoots out from the middle of the prop) to allow a) less cavitation...when plate down it gets louder down there for obvious reason, and b) allow for additional forward thrust while still blocking most of the thrust from the prop and allowing the exhaust water to flow straight out and hopefully quiet it down some what....
thoughts? bad idea?
Also it would alleviate some stress from the cavitation plate where the happy troller mounts.
thoughts? bad idea?
