how do you get this off?
cgd7777777
1997 Larson 206 SEI
Volvo 5.7 gs
cobra sx outdrive
how do you get the control off the boat??
it is hard to get into reverse even when I uncoupled the linkage at the outdrive
sometimes i have to wiggle the lever to get it to turn over like its not making good contact
the other day i was running about 3/4 throttle when i went to throttle down it would only throttle down to about an 1/8 even when i got it neutral
turned it off and it fired right up and idled just fine
can the controls be repaired or easier to replace
Thanks!
cr2k
Re: how do you get this off?
Pull the little boot out of the center and you shall be enlightened. A phillips screw on the button then a nut on the handle.
cgd7777777
I pulled to boot off and removed the button but no nut on the handle
captk
Maybe an allen head screw on the bottom of the handel?
