Re: 50 HP Force loosing power past 1/2 throttle
A similar problem here too.
How does changing the gear oil help?
I bought a 85 bayliner and it has a 85 force.
The guy said it ran strong last summer.He hit a rock,so i put on a new prop.
The problem is it runs fine up to almost 1/2 throttle,then boggs out.
Also runs fine going slow.
When i hit full speed throttle,it takes off,and then dies down.
Cant seem to get full speed out of it.
Plugs are new,did a decarb on it 3 times,and was still smoking,but im sure that is fine.
Used a new tank of gas,and new tank and did the same,so figured out its not that either.
checked the wire filter on the motor,it was good too.
Also checked the diaphram,its good.
Pumping the bulb did not make a difference either.
Any advise on what would be next to check?
Thanks,
Scotty
P.S.
Mabe a good way to check for spark might be to pull one wire at a time,and start it hu?
If i would notice a difference,that would tell me im getting spark correct?
Newbee scotty
