Re: my bayliner just bit the dust!!!!!!!!!!!!
hey guys, thanks for all the replies and input. I am getting started on tearing this pos apart. upon further investigation this disaster seems to be caused by sorry craftsmanship! the mechanic that rebuilt the engine apparently dosent know a nut from a bolt and has never heard of locktite. the nuts on #1 piston rod backed off which allowed the bolts to shear slinging shrapnell thru the side of the block. i will post pics tonight (wife wont let me touch the camera with greasy hands). after looking @ the other engine, the block is exactly the same, the head appears to be the same, the differences seem to be, as far as I can tell, the distributer, intake, exhaust, thermostat housing, the cam pully for the distributer where the impeller pump shaft connects. I would definately have to strip both engines down to the block & head then swap everything over. I just dont know if its worth putting the extra money into it. you guys give me your input;
boat and trailer: 1500.00(did not run properly)
impeller x 2: 92.00
exhaust bellows: 96.00
distributer cap :49.00
rotorbutton:12.00
plywood floor: 60.00
lights: 60.00
seats:90.00
thermostat: 40.00
investment so far:$1999.00
work that still needs to be done: 1) stringers and transom replacement ( not certain they're bad, but might as well now) 2) buy new propeller 300.00 est 3)
buy 1983 volvo 240l just for the engine 500.00.
looks like a minimum of $3000.00 for a 1986 model boat. I just dont think this small and old a boat is worth that kind of money.
