jwcornwell
- May 20, 2010
- 2
Motor is 1994 Evinrude 225, model # E225TXERK Ser. #G03545264
Power tilt works down but not up.
Changed engine switch & relay. It worked twice, then same symptom - works down but not up. Swapped relays - same problem, so I am confident the problem is not the switch or the relay. Any ideas?
Thank you.
Thank you.
