I have a 75 70HP Johnson that seems to be having fuel related problems. There are 3 carbs on the engine, the middle one being the main one that connects from the fuel pump and then has a separate outlet that splices to the other two. All the lines are getting fuel, but the carb bowls don?t seem to be filling up. I have tried to crank ad crank to get it to start up, but it won?t. When I put some starting fluid in to each carb and it will start up but then die. I hope I'm posting this in the right section, thanks for any help you can offer.
