i have a glastron mx 175 with a volvo penta sx and it seems to be making a rough sound when i turn left or right or when i put the trim up above normal but when i go straight it goes away. so i dont go to fast or make to many turns with it. i had a reply that it could be the u joints and to pull out the drive and have a look. what could be the problem? and is it easy to pull out the drive? oh and i took it out just recently after i got a new prop (the last prop was bad)to see if that was the problem and its still ther and it seems to be leaking a bit of water but not much. its never happend before? any ideas i could use the input and HELP??
thanks for the advice 83Evinrude is this something that i can do myself? is it easy? and should i do this befor i take the boat out again?thanks for replying so fast ive been busy!
